I've never really looked at what people are using for battery chargers. I'm using a couple different chargers, and will hopefully be able to narrow it down to two or three chargers if possible. Input is welcome, thanks.
Zaine Stapleton
ShannonCloud said
Jun 10, 2010
we use:
Lester (25 amp battery charger that will charge up to 16 volts per battery)
Manzanita Micro (37 amp charger, fully adjustable, but more expensive)
stan r said
Jun 12, 2010
BATTERY CHARGER. Mine is Guest, model16102, 2 bank, 12/24 volt, 6 or 12 amp, any lead acid battery, you may leave it connected all year, about $ 135 Stan r
the biggest thing with a low cost charger is how long will it take to charge back up a battery(s). Low end chargers like the NAPA I have found with similar ones will take up to a day or two to recharge a dead set of batteries. With a high end one, like a Shumacher (about $70-90) with a set of yellow tops can take about 6 hours to recharge a dead set of yellows.
It depends on how much you really want to spend. I went through a couple chargers before I was satisfied with one type of charger and have had good success with it.
Hope this answers your question. Zaine
-- Edited by Zaine Stapleton on Wednesday 22nd of September 2010 03:41:34 AM
-- Edited by Zaine Stapleton on Wednesday 22nd of September 2010 03:43:19 AM
-- Edited by Zaine Stapleton on Monday 15th of November 2010 08:16:52 AM
Zaine Stapleton
