I have been working on ways to build interest in the EA program ...& trying to expand it here in Ohio
The only printed info, about the program, is the rulebook ...but, it is ~50 pages (a long read & kinda expensive ta make a bunch of copies ...&/so, I have been working on a (1) page tri-fold brochure
First, I drew up a mini-brochure to help organize the info
Then, mainly just cut & pasted, most of the main points, right from the EA rulebook
Once all of the main ideas/info was arranged, I worked on making an actual brochure
Printed info on both sides (here is what the front/out side looks like)
Then, just had ta fold 'em into 3 sections The centering could use some work ...but, they are an easier read ...way more cost effective ...& will work for now, to help "get the message out there"
Well, to further the discussion "for the program", I'd like to suggest/make a few adjustments to the tri-fold flyer
1.) Mission:
The acronym STEM (Science, Technology, Engineering & Mathematics) is now used quite often in the education field
So, I'd like to re-arrange the terms
...& add Mathematics to the mission statement
2.) Vehicles:
I'd like to simply remove the (antiquated) term "lead acid" from:
"They are powered by standard sealed (won't leak if damaged) Lead Acid battery packs not exceeding the weight limit specified in the vehicle design section"
So, it will then say "They are powered by standard sealed (won't leak if damaged) battery packs not exceeding the weight limit specified in the vehicle design section"
Anyone have any thoughts on these slight adjustments?
I did some adjusting on the borders ...some slight editing ...& also, added a splash of color
1.) original mission statement Our MISSION: To inspire an interest in Science, Engineering, and Technology by involving participants in the design, construction, testing and development of competitive electric vehicles.
So, I added "Mathematics" ...& also, re-arranged the words Science, Engineering, and Technology ...to Science, Technology, Engineering & Mathematics ...or STEM (like used in many school systems)
2.) original text under Vehicles
VEHICLES Electrathon vehicles are single person, lightweight, aerodynamic, high efficiency, electric vehicles with three or four pneumatic tires. They must meet specific design and safety rules. They are powered by standard sealed (wont leak if damaged) lead acid battery packs not exceeding the weight limit specified in the vehicle design rules section.
I removed "standard sealed (wont leak if damaged) lead acid" ...& simply inserted "(up to)1kWh"
VEHICLES Electrathon vehicles are single person, lightweight, aerodynamic, high efficiency, electric vehicles with three or four pneumatic tires. They must meet specific design and safety rules. They are powered by (up to) 1kWh battery packs not exceeding the weight limit specified in the vehicle design rules section.
Outside
Inside
I'm working on a post able link
...so, anyone that may be interested in this flyer out can print it out
What do you'all think?
1.) Mission:
2.) Vehicles:
VEHICLES
VEHICLES
Outside
Inside
Anyone/everyone should be able to download & print the tri-fold flyer
...using these attachments
Outside
EA tri fold front (1) (5) (2).pdf
Inside
Electrathon America (2) (4) (3).pdf
*Edit: Well...I guess that didn't work
...still trying
-- Edited by Functional Artist on Wednesday 20th of November 2024 08:03:48 PM
-- Edited by Functional Artist on Wednesday 20th of November 2024 08:06:24 PM
